system won't boot when I overclock??
14 Jun 2017
Motherboard : gigabyte ax370 gaming k7
Bios : F31
Ram: G.skill F4-3200C14D-32GTZ ( XMP Enabled )
GPU : Vega 64
PSU: 750w corsair
I overclocked my on 3.9 , it was all fine, then I updated the Bios to F41, overclocked using same settings, everything was working fine for few days when suddenly system refused to boot.
after so many testing i found out if I set the system on 3.9 , not Auto , it won't boot. i did not try other than 3.9.
I changed back to the older Bios , increased the voltage, cleared CMOS, as my motherboard has dual Bios tried to switch. nothing helped, have to keep everything auto.
also for few months ago, when am not using the overclock settings , even if I keep CPU on auto , speed stuck on 3.7.
hope this is not a CPU or motherboard issue?
