Hey I was wondering if anyone could help or tell me what the problem is.
I have a system which has trouble booting.
It's not too old only about 2 years or so and has been having problems lately.
-takes a long time to boot, sometimes stuck on the very first boot page with no option to continue or anything, and sometimes I can't even get into the setup by pressing DEL. (has trouble identifying all/any my IDE drives i think)
-when Windows XP eventually loads, nothing happens, I only see my desktop picture. I have to go into Task Manager to end explorer.exe and then run it again for explorer to load.
-once I'm in I start a program, iTunes let's say, and it takes literally 2-5 mins to load, this applies to nearly all programs I try to start up.
Then most recently the system won't even boot.
-the booting up seems ok but after the "verifying DMI pools" it comes up with the page where you choose to start Windows in Safe Mode, Safe Mode with networking, Safe Mode with MS-DOS, Last Known Good Configuration and Start Windows normally.
-I have tried every one of those options and each time it starts loading the screen where you see the Windos XP logo and the loading bar. However, after that, the screen flashes, in less than a second, with a blue page with about 2 paragraphs of white writing and then one line underneath with some sort of code. It flashes so fast I can't read it at all. So after the flash it just restarts my system and it starts all over again bringing me back to that same page with those options.
-I have tried going into CMOS and choosing to load the "fail-safe defaults" and "optimized defaults" with no effect.
-The motherboard is an Abit uGuru KV8 PRO
-The Processor is an AMD Sempron 1.8GHz, although the BIOS sees it as an "AMD Hammer Family Processor".
-The RAM is just regular 1gb(2x512)
-The Graphics card is a GF 6200A 256MB
Can anyone help me or has seen something similar?
If anyone wants any more information about the system please ask!
Cheers in advance.
"stiffyboy"
P.S. - By the way, I'm pretty novice when it comes to this sort of thing, so I might not understand some technical terms you might say.
Cheers in advance.
"stiffyboy"
