Hi Folks
Just a quick technical heads-up.
We have had a lot of support queries recently from customers who have wiped their overclocks from their OcUK Systems and Bundles.
The reason for this is because when you update the bios on your motherboard, it removes any overclock settings that you had before.
The way we overclock means that each system is individually configured and optimised to ensure that the CPU is running at the most efficient voltages.
The BIOS profile saved onto the motherboard will be unique to your hardware.
By updating the BIOS you would remove these settings.
If you have to update the BIOS on your System or Bundle then there are two ways to go about it
1. Make a note of the settings in your BIOS by looking through the overclocking sections and writing down your settings. I personally suggest using a camera to take pictures of the settings as it is easier.
2. Call our Systems Support line or contact myself directly using our Customer Support Forum, this way I can assist with any queries directly.
If anyone has any queries at all, please ask here and I will try my best to help.
rjk
rjk
