T-Balancer and wrong driver now emits a long beep
18 Jun 2003
Southampton UK
Hi vista today automatically installed a memory card driver for my T-Balancer and now all it does is turns the fans on full and emit a very long high pitched beep does anyone know what this means? I wouldnt have thought such a thing would break it?? Any ideas appreciated
I have exactly the same problem luckily im on a dual boot system and if i log back into xp and re load my old profile it fixes it but im also looking at a fix will let you know
as long as it is fixable by loading on the old profile i have yet to try that as im away for a few days. Have just gone back to the original driver in vista will let you know on sunday if i can get it working again
These T-Balancer thingys would i be able to hook up my DCC pump to it to monitor it`s rpm,as my cpu pump stopped working the other day.
yeah you can hook up a pump to them you can use it slow the pump down too. have a look on there website just search in google for it you can use them to control/monitor most things in your pc such as fans, lights, water pumps, temperature probes etc is a very good piece of kit when you get it up and running just hope mine isn't dead!!!!
If you just rollback the driver in vista to the normal t-balencer one and then reload your profile it works. Then all you need to do is uninstall the update and tell windows to hide the update so that it isnt accidently installed again. Glad that mine works would hate to be without it!!!
