T-Balancer bigNG
31 May 2005
Alfreton,Derbyshire
Or event the classic for that matter...
It says it can control 4 fans which is great but....
I would like to control 2 x 120mm intakes
1 x 120mm out
1 x 80mm out
1 x 92m out
CPU 120mm
GPU Zalman VF-900
is there anyway to control say 6 fans at all?
Say link the 2 front intakes into one channel or something? with some kind of 2 - 1 splitter if they exist?
I have 2 zalman fan mates also, but would like to centralise my fan management...
Any thoughts appreciated
Yep if you look on the Mcubed site you are after what are called attenuators. Basically you can connect 2 fans to one attenuator and then the attenuator connects to the t-balancer unit. So in all you can have 8 fans running, but control wise you will be controlling the fans in pairs, ie 4 x 2 pairs of fans if that makes sense.
