As an alternative for mere mortals, try auto glym super resin. Menz is brilliant, but overkill on a white van, and you really need a rotary to get the best ut of it.
AGSRP is a good filler polish and will do a good job, but if looking to remove scratches as opposed to hiding them then a scratch removal polish would be better.
My problem with t-cut is that mere mortals can overdo it and damage the paintwork. A less abrasive polish will do the job with a lower risk of damage being done to the paintwork.
