Hi Folks,
I've just upgraded my mobo (MSI Z490 Carbon Wifi), processor (intel i7 10700K), cooler (Dark Rock Pro 4) and had it working with my existing G.Skill Ripjaw DDR4 2400Hz.
Ordered T-Force DDR4 Xtreem 3600MHz F10D48G3600HC18JBK and installed.
Sits on black screen - no entry to Bios or Windows.
Returned to older RAM and enabled XMP then tried new RAM again.
It's been suggested on another forum that the RAM training can take some time but not so sure about that Q1) how long should it take?
Am going to return the T-Force but will need an alternative.
Q2a) Was thinking of HyperX Predator 3600MHz C17 - https://www.overclockers.co.uk/king...l-channel-kit-hx436c17pb4k2-16-my-28e-ks.html
Will this be ok?
Q2b) Anyone know if the height of this option is larger than the RipJaws (which only just sit beneath the cooler)?
Answer: Ripjaws appear to be 42mm with HyperX 42.2mm. T-Force appear to be 49mm which is why I have a tight fit under the new cooler!
Thanks in advance!
TAJMR
64 bit Windows 10.0 Pro.
MSI MPG Z490 Gaming Carbon WIFI (Socket LGA 1200) DDR4 ATX Motherboard
Intel Core i7-10700K 3.8GHz (Comet Lake) Socket LGA1200 Processor - Retail
be quiet! Dark Rock Pro 4, 250W TDP, CPU cooler
16GB DDR4 G-Skill F4 2400 CI5-9GVR RAM
Asus Nvidia Turbo GForce GTX1070
M2-1 NVMe Samsung SSD 960 250GB
M2-1 NVMe Samsung SSD 970 500GB
Samsung SSD 850 EVO 500GB
Seagate 1.5TB Barracuda hard disk
Crucial MX500 CT1000MX500SSD1(Z) SSD 1TB
Will this be ok?
Thanks in advance!
TAJMR
