I've searched this already, but all I get are motors threads.
Anyways, I've noticed that Core Temp shows that I have a 'T-junction' that's either running at 85 degrees or is set to 85 degrees - if its a setting (which I suspect, as it doesn't change) then what is it, and if its a component on the motherboard, should I be worrying?
(I'm slightly paranoid about my Northbridge too, since the Freezer 7 is literally a millimetre above it, and I'm hoping it won't have any adverse affects).
As an aside, I've got no idea of my load temps (yet) but idle temps are 20 and 22 degrees on each core respectively of an E2180 @ stock. I'm leaving it a while before I start clocking it - I want to make sure the system really is properly stable. Besides, I haven't been disappointed with its performance at stock so far.
:edit:
Ah, and another question while I'm here. Core Temp reports my CPU frequency as '2004.71Mhz' all the time, and at '204.71 x 10' most of the time...but earlier one after un-RARing some files, it displayed the same frequency at '33- x 6'*. That looks like the computer actually overclocked itself? I dunno if Core Temp was malfunctioning (0.95.4 beta version, I think) or if the PC can actually do that. I'm aware that Speedstep and similar things can drop the multiplier to reduce CPU speeds/temps when idle, but how the hell did it increase the FSB? And more importantly, what if my RAM hadn't been capable of that setting? The PC would have randomly crashed, and I'd have been none the wiser.
*the - is because I can't remember the exact freq, but it began with two 3s. A little arithmetic would get you the exact frequency if you were all that bothered.
Final question - the last motherboard I had came with a monitoring software that kept a record of system temps etc, so I could look back after playing a game and see how hot it had been getting. Is there any free software that does something similar for Gigabyte boards?
:edit:
