- 13 Mar 2006
As title - does where it is in the loop make a difference? I was going to put it after a radiator and before the graphics card block...
It makes things easier if you put it at the top of the loop for filling, bottom of the loop for bleeding, before the pump makes it easier too. But in theory you can place it wherever you want.
I don't have a water cooled system, but going on hydraulics... why would you want the bleed at the bottom when the air travels up?
I can see if it is on something like a brake caliper where the nipple is at the bottom of the loop but at the top of the brake caliper where air may be trapped.... is it for a reason like this?
Matthew
Decided to clamp the tubes rather than than bleed the whle system to take the pump apart.
. Running pumpless underclocked with fans at full whack atm!
