yeah its not as if i fitted the cooler incorrectly either... oh well live and learn...
Im thinking the bases of the T-rads are different thickness on some. It only takes a couple of mm then you have a big problem.
1.There wasnt enough clearance as the heat pipes touched the base plate before making proper contact with the gpu core (had to really tighten the t-rad on to get any contact with the gpu core)
2. The ends of the heatpipes protruded the other side of the t-rad base plate so that also stopped the t-rad fitting into the space of the base plate!!?
