T-SQL help - order by a particular value
1 Feb 2006
I have a fairly huge T-SQL stored proc that I need to update for a colleague. There are a load of different values in one column such as open, created, pending etc.
I want to sort the results so that 'pending' is returned first. Obviously I can't use ASC or DESC here. Is there any easy, quick and obvious way to do this that I am missing completely?
How I normally do this is to dump the data into a temp table, add a column for rank, then update the rank column with an int for each type, in your case pending = 1, created = 2, open = 3.
Then SELECT * FROM @TempTable ORDER BY Rank
Why not just create an OrderBy table with two columns: Type (String) and Order (Number). Populate with all the types and add a numeric order for each. Then join the OrderBy table back to your main table using Type and sort by Order.
create table misc_stuff(status nvarchar(16))
go
insert into misc_stuff (status) values ('pending')
go
insert into misc_stuff (status) values ('created')
go
insert into misc_stuff (status) values ('open')
go
go
go
go
select
case when status = 'pending' then 1
when status = 'created' then 2
when status = 'open' then 3 end as rank,
status
from misc_stuff
order by rank
go
drop table misc_stuff
go
Results:
rank status
1 pending
1 pending
2 created
2 created
3 open
3 open
6 record(s) selected [Fetch MetaData: 0/ms] [Fetch Data: 0/ms]
Edit: If you don't care about the ordering of the non-Pending rows then just drop those ranks and have a catch-all 'else' instead of 'when', I suspect you might have a preference for order the other values follow in too, but your specs were only for pending to be sorted first so unsure.
Thanks I got this sorted in the meantime. I used a ORDER BY CASE WHEN something THEN 1 ELSE 2 END, fieldname. Found it in google and it worked.
Yeah, same deal I guess as far as the DBMS' optimizer is concerned.
Better (if it can do this in memory, and treat it deterministically,) than doing unnecessary I/O with temp or physical tables IMO though either way.
