T.V recommendation
13 Feb 2009
London
Hi,
Could someone please recommend a 42" T.V where i can use plex, free view HD, and whatever you would recommend.
It's for watching t.v and films mainly.
I know it won't be the tops, but £360 max is what a want to spend.
i see this PANASONIC VIERA TX-42AS520B Smart 42" LED TV :) can i use plex on this t.v?
Or would you recommend something else?
Cheers :)
If you want Plex I would recommend a Samsung as the Plex app is just available as are all the other On Demands you would most likely want.
Only thing though they only seem to do 40 or 48 inchers.
If you have to have 42" then it might be best to get the TV you like and add on a chromecast or Apple TV.
So this PANASONIC don't have plex. if not, what other 42" model would you recommend that support plex?
Cheers :)
