21 Oct 2011 at 20:52 #1 han_solo han_solo Associate Joined 11 Mar 2009 Posts 1,061 Hi there, using stock cooler with a tiny but very loud fan and getting above tmeps. Ambient is around 23 ish. Should i be worried? If i should then any recommendations on how to get load temps down? thanks!
21 Oct 2011 at 20:59 #2 SupermotoMX SupermotoMX Associate Joined 22 Feb 2010 Posts 1,088 re seat / reapply the TIM?
21 Oct 2011 at 21:05 #4 SupermotoMX SupermotoMX Associate Joined 22 Feb 2010 Posts 1,088 quick google says maximum operating temp is 100c, so i would say its fine as it is
21 Oct 2011 at 21:14 #5 han_solo han_solo Associate OP Joined 11 Mar 2009 Posts 1,061 you sure? so even if i hit 90c on load... it'll still be fine? :S
21 Oct 2011 at 21:47 #6 SupermotoMX SupermotoMX Associate Joined 22 Feb 2010 Posts 1,088 yep, (i iguess because its older its been built to run hotter) if you wanted to improve temps / noise level you could look for an aftermarket cooler, only chance i think it will be is on the bay though
21 Oct 2011 at 21:49 #7 han_solo han_solo Associate OP Joined 11 Mar 2009 Posts 1,061 that's interesting, never thought of these chips like that. you've eased my concerns, thanks
