t300rs mounting
21 Oct 2002
Behind Melmac, ssshhhhh
Hi all, got t300 for Christmas but it won't mount on my table due to it's design.
My search skills came up dead, what are other owners doing/using?
sounds like you want something like a wheelstandpro or GT omega wheel stand.
I personally use and recommend the gt omega wheel stand, it folds up very easily with the wheel still attached for storage, its also upgradable so you can add the rear seat section etc at a later date.
Is it similar to what happened to him?
I don't use these clamps since it is bolted to the Playseat holder.
will check those out thanks :)
@V F my problem is not enough desk to clamp, cheers for vid though :)
