T5600 temp laptop CPU temp....
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Is 91C under load too high for this laptop CPU?
I'd guess so but not sure 100% as it maybe manufactured to be able to run higher (doubt it though)
speedfan and Everest according to him
He has opened him laptop and blew out the dust and is getting 55C now :)
lol, also try running coretemp instead. Speedfan often gets its reading wrong if its not been configured for the motherboard (and it hasnt for most - particularly laptop boards). I think Everest is normally quite accurete, but it depends which reading he is looking at. IIRC it has 3 temps listed under sensors, the one that just says CPU is way out, but the temps of the individual cores are about right
