Tablature question
30 May 2005
Greater Manchester
Quite often you get a tab which people write the chord above each bar.
Does this mean that is the chord you form, or that is the nearest chord, and then you figure it out ? Like this:
Do you form an Am and then just stick your pinky on the 3rd fret ? - because it isn't just an Am is it ?
If they don't write a chord, do you just have to figure it out for yourself ?
Go easy here, I am very new to this guitar lark... :p
You can just ignore that chord. The progression you play is Asus-Am-Aadd9, or these three chords as indicated by the tab;
Asus
0
3
2
2
0
0
Am
0
1
2
2
0
0
Asus2
0
0
2
2
0
0
The Am chord above indicates these chords are variations within the Am "bracket", and if you were playing with a friend one of you could play the Am while the other plays the picking pattern. Street Spirit of course. :D
This tab might help more;
Code:
    Am              Asus4           Am              Asus2
E-|---------0---------------0---------------0-----------------------|
B-|-----------------3---------------1---------------0---------------|
G-|-----2-------2-------2-------2-------2-------2-------2-------2---|
D-|---------------------------------------------------------2-------|
A-|-0---------------------------------------------------------------|
E-|-----------------------------------------------------------------|
FIG 2:-
    Em              Em7             Em6             Em
G-|-----0-------0-------0-------0-------0-------0-------0-------0---|
A-|-----------------------------------------------------------------|
E-|-0---------------------------------------------------------------|
FIG 3:-
    C               Cadd9           C               Cmaj7
A-|-3---------------------------------------------------------------|
That's my understanding anyway, I await to be corrected since I have no formal training. :p
Thanks very much for that.
So how are you supposed to know that ? - Or do you just figure it out. I was under the assumption that you grab and tab and away you go. There seems to be a bit of work needed to actually use it to produce the song from it...
Another quickie:
you wrote;
Asus2
0
0
2
2
0
0
But I was watching a tuition DVD over the weekend that said that was A5 (or the A powerchord). I just doubled checked online and some sites have A5 as you have shown it and other have it as a 1 string thing.
Wow this is confusing !
The other sites are wrong I'm afraid! A power chord is by definition only three strings so an A5 is actually;
2
2
0
Nah, not really. The tab tells you the notes and all you have to work out yourself is how to finger (ooh er missus) the chords.
Not strictly true, a powerchord is a 'chord' with only a 5th inteval, so with that you only strictly need to play
x
x
x
2
0
x
The second fret played on the D string is an A, just an octave higher, so it's the same note. A powerchord is such because it doesn't have the 3rd interval to say whether it's a major or minor.
