Tablet backups
5 Nov 2014
Hello All,
wonder if anyone can help.
recently I had to take back my sons tablet for a replacement, at this point I took the chance to get the next model up as it was better spec'd.
before this I used to use the Asus backup, was great and did what I wanted.
On his new tablet with newer version of Android (Android M I think its called) the Asus backup no longer supports backups but allows you to restore only.
Does anyone have any good suggestions for backup software? it has a SD card in which I used to backup too using the above software. had a quick look on the store but all the free ones had ads and where not very good.
All I would like to do is backup his game data and progress.
thanks a lot
