Tablet I can use my SD card with
8 Dec 2006
Hi all
Ive searched google but struggling to find what I need!
I have my Nikon camera that uses a full size SD Card.
I want a Tablet I can use that will let me see the pics on.
I cant see any tablets with SD Card slots built in. But, ive heard about some USB adapters you can get for some tablets?
Can anyone please help and suggest something for me?
My budget is £300 but ideally looking around £200 if possible!
Thanks
Dell Latitude 10 from the Dell Outlet would get you under 300. Not perfect devices, and the screen's not exactly iPad resolution, but it's a good quality display and if you want full size SD there's not much choice, sadly.
An option is to buy a micro SD card with an adapter and use that in the camera, you can then get any tablet with a micro SD slot. This widens your options.
Interesting!
With the galaxy tab 3, it has a micro USB port.
Can I buy one of them micro USB SD Card readers and plug it in? Then it should let me browse my SD Card right??
