Tablet with HDMI
28 Sep 2004
Devon, UK
Hi there,
I'm looking for a tablet around £200 - £250 which has HDMI Output and is ideally 10.1"
I've seen the TAB 2 but conflicting reports as to if the HDMI adapter actually works with it or not?
Does anyone have a tab 2 and tried to use the hdmi adapter?
Thanks
I can tell you 100% the Galaxy Note 10.1 has HDMI (or MHL to be precise - you need to buy an adapter) and the seller I bought mine off on (oh let's call it d-bay) states on their site that it works with the Tab 2.
As an aside, having owned both I would wholeheartedly recommend shelling out a little bit more on the Note 10.1 than the Tab 2.
Yeah they both look great but the difference in processing power is so noticeable - and the S Pen is pretty nifty.
I have seen the Notes on sale for £250-£270ish - for the white ones anyway.
