Tack in Tyre
20 Aug 2006
found a tack in one of my wife's front tyres yesterday
pulled it out today - it was right in the corner/between sidewall and tread - looked about 1 1/2cm long or so
the tyres are pretty new (all 4 about 4 months or so)
if the tyre doesn't go down overnight/next week - is it safe ?
cheers
If it's not going down it will be fine. Easiest way to check is just put soapy water over it and see if it bubbles up.
