Tagan PSU - Split or combine?
28 May 2006
I've recently replaced my PSU for a new Tagan Modular 580W (TG580-U15). I have an NF7-S motherboard and wondered whether the switch on the back for the 12V rails should be combined or separate? Or doesn't it matter?
Cheers!
Hi,
The NF7-S board
XP-M2500+ (1.65V, 2200MHz)
2x512MB PC3200 RAM
ATI R9800Pro
3x Hard drive
1x DVD-RW
1x DVD-ROM
Think that's all :)
sorry to butt in but can i also have an answer to this same question, same PSU.
i just use it on combined at the moment.
spec is in sig, if you need more detail gimme a shout.
Dragging up my old thread... I now have a nice new Core 2 Duo set-up to put together.
E6400, P5W DH, 2GB GeIL RAM, 2x300GB HD, X1900XT.
Based on the above posts, I'm guessing it should now be changed to separate?
So if say i was running my single x1800xt with my PSU on combined, could this cause any problems? (IE: Crashing, graphical errors etc)
Edit: The guy from Overclockers who replied to one of my webnotes said:
"If you have just the one video card then it will be better to have the combined
rail"
now im intrested.
1 graphics card = combined i think ?
2 graphics cards = split.
or is it the other way about as i have been running in combined mode and my x1900xtx has been drawing about 30-35amps when in 3dmode....
and my 12v rail has been droping to about 11.97v-11.94v
if i run in split mode wont that reduce the ampage even more
i dont even understand why the 580w psu is running down into the under 12v line as 35amps should be plenty for 1 graphics card.....
and im hopeing when i buy the x1950xtx that this psu will also run it fine or im foo***ked :/
