- 5 Feb 2006
Evening gents.
A couple of wee questions.
First one is about tagging : I download a lot of vids from youtube / vimeo etc. Its all work related but I have started tagging them using a program to then find certain scenes. I use a program called Leap, not that that really matters. I believe it tags in OpenMeta and the "offcial" finder why. So ... are the tags stored to the file its self ??? There is a folder in application support for OpenMeta which to me seems to have the files.
The second question : Relates to the first. Because I have so much I have quite a few external HD's and then some to back them up. Say I tag a file quite a few files on the HD and want to back them up. Is there a way that it only copies the adjusted ones. At the moment all I can think of is to essentially copy over the whole HD to make sure its all completely backed up.
Some thoughts and maybe suggestions, this may be the stupidest way of doing it
cheers chaps
cheers chaps
