Take a look at my build
23 Jan 2011
Aylesbury,Buckinghamshire
Hey guys, I will be spending around £900 on my next computer build.
The main things I want it for is, Rendering HD videos, Animation and Gaming
I want to get the best hardware I can for the money. I also want the case to look good and so on. So here are the parts I have researched to be good for what I want.
Case - NZXT M59 - Already bought this
PSU - XFX P1-750B-NLG9 Black Edition 750W
CPU Cooling - Corsair H70 Hydro
CPU – Intel CPU Core I7 2600K Unlocked Sandy Bridge (Will be overclocking)
Motherboard – MSI P67A-GD55 P67
Memory/RAM – Corsair Memory Vengeance 16GB DDR3 1600 MHz
HDD - 2TB Samsung HDD
Crossfired GPU - x2 XFX HD 5870s
Fan Controller – NZXT Sentry LX Fan Controller
Other Fans – x5 blue LED Fans
What do you guys think about this and do you have and suggestions ??
The motherboard there lets me overclock the processor with a button on the board so ill be doing that.
Thanks
Luke
Im not sure about the size of the case, i though it was a micro atx case? ( hopefully im wrong :D ) 16 gb of ram is so much over kill, drop it to 8gb and maybe try and grab 2 6950's :D
The MSI P67A-GD65 has a few extra connections and dual BIOS for £10 more.
I have 2 and they've been faultless so far.
6950's would be better than 5870's if you can flash them and afford the extra.
GTX 560s are being released in a few days and will be right inbetween the 5870 and 6950 for price and performance, they may be worth waiting for.
Okay, I can afford this I have done some shifting. What do you guys think of this ??
8GB (4x2GB) Corsair XMS3 Classic DDR3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 9-9-9-24, XMP, 1.65V
NZXT Sentry LX Fan Controller, Black, Double Decker needs 2 x 5.25" Bays
120mm Antec TriCool Blue LED Manual 3-speed switch 3-pin & 4-pin connector Fan speed monitoring
750W XFX Black Edition, Modular, 80 PLUS Silver, 88% Eff', SLI/CrossFire, EPS 12V, 135mm Fan
MSI P67A-GD65 Motherboard
Corsair Hydro Series H70 High-performance CPU Cooler, LGA1156, 1155, 1366, 775, AM2/AM3
(Two) 2GB XFX HD 6950, PCI-E 2.1 (x16), 5000MHz GDDR5, GPU 800MHz, 1408Cores, DL DVI-I/ DVI/ HDMI/ 2x mDP
Intel Core i7 2600K Unlocked, Socket 1155, Sandy Bridge, Quad Core, 3.4 GHz, 8MB Cache, 95W, OEM
HDD 2TB (Bought already forgot to mention)
Ok this is what I have now. I stretched the budget quite a lot >.>, yes i would like the I7 as I have seen in many places they have made it future proof. Plus i do video editing so it will be good for me.
Sentry LX Fan Controller, Black, Double Decker needs 2 x 5.25" Bays £38.89 £46.67
120mm Antec TriCool Blue LED Manual 3-speed switch 3-pin & 4-pin connector Fan speed monitoring £15.94 £19.13
750W XFX Black Edition, Modular, 80 PLUS Silver, 88% Eff', SLI/CrossFire, EPS 12V, 135mm Fan £74.75 £89.70
90CM STRAIGHT - R/A SATA I/II DATA CABLE WITH LOCKING LATCHES £0.92 £1.10
Corsair Hydro Series H70 High-performance CPU Cooler, LGA1156, 1155, 1366, 775, AM2/AM3 £61.29 £73.55
12GB (3x4GB) Corsair XMS3, DDR3 PC3-10666 (1333) Non-ECC Unbuffered, CAS 9-9-9-24, 1.5V £99.20 £119.04
2GB XFX HD 6950, PCI-E 2.1 (x16), 5000MHz GDDR5, GPU 800MHz, 1408Cores, DL DVI-I/ DVI/ HDMI/ 2x mDP £383.38 £460.06
Gelid Solutions GC-Extreme Cutting Edge Thermal Compound 3.5g £5.98 £7.18
2TB HDD
It would work, but why not get a 2X4GB kit and leave two memory slots empty for more?
and only the i7 socket 1366 is triple channel.
