Take case apart
31 Dec 2010
Kent, UK
Hi,
I've got my old case a cm storm enforcer and I want to take it apart to use the separate panels in a new custom build. Does anyone know an easy way to remove the little holding bolts which fasten the sides together?
If you don't know what I'm talking about please say and I will post a picture
Thanks
Dom
You mean the rivets? If so the easiest way is to drill through the head with a 3mm drill if you can get in there, if not knock the heads off with a hammer and chisel.
Thanks for the reply
Yeh thought it might come to that, I was hoping there was a tool for screwing them out but never mind I'll take a drill / chisel to it.
Thanks!
Dom
