Takes Ages To Start Up
8 Aug 2011
Hi all
On my pc running vista, after the loading bar showing "Microsoft corporation" finishes, the computer screen will turn off do about half a minute until it shows the windows logo followed by the login screen, not major but is there any way to make it faster?
Hi all
Ok... well you haven't given much info, but i'll try my best. it could be one, problem, or multiple problems:
> Go into msconfig (type into search bar on start) and check the startup items. disable all the ones you don't really need.
> Vista is generally very slow. my old machine running vista had the same sort of problems that you mentioned. i would suggest getting windows 7, or waiting for windows 8 (if you like the new layout).
> It could be your hard drive. If it is old, it will tend to slow down boot times, and maybe shut down times too. i am in the process of upgrading to an ssd because my 5 year old hdd is way too slow for my liking.
> If your hdd is more than half full, this can also slow systems down. try doing a disk cleanup (right click/properties/cleanup). also delete unused files.
> It could be a virus. update your antivirus, and do a virus scan. if you don't have an antivirus, i suggest malwarebytes as your best bet.
> Check task manager to see how may tasks are running, and to see which ones use the most memory.
> If worst comes to worst, you can always disable aero, although it won't do to much.
Hope this helps :)
What further info do you want?
It all started when I was on Facebook, I knew I stopped the update but all of a sudden the screen went to power saver, it stayed on it forever so I turned off the PC then as it rebooted the windows update proceeded then it restarted and the slow boot time kicked in, when I logged Mcafee told me that it had removed a Trojan but its been saying that a lot recently, I will download mallawerebytes and run a scan over the weekend
Ok, tell me how you get on :)
