So, we have BT FTTP Full Fibre 900. It's great, but what's even greater about it, is that when connected via a network cable to the router, we often see speeds over 1.2gbps - 1.4gbps. What's not great is the office is on the floor above where the router is and therefore is currently connected via Wifi. Sadly this only returns approx 430mbps.
For normal use this isn't a problem, but there are times for work I transfer a lot of video files / image files and also any game updates etc.
Also, given we can achieve these connection speeds, it would be great to actually capitalise on them.
Therefore, I'd like to create a hard connection between my office and the router. I've established there is potentially a route down inside the stair well (inside the wall) and I'm not worried about the DIY elements.
My challenge is, what exactly do I need cable/connector wise. Ideally, I'd like to terminate each end with a nice face plate, then run a short lead into the router / computer (ends respectively). From my research, I believe I need the following:
CAT6 UTP Solid Core Cable (approx 15m, appreciate I'll likely have to buy a roll)
2 x CAT6 RJ45 Face Plates
2 x CAT6 Terminated Network Cables (from faceplate to respective devices)
1 x Punch Down Tool
1 x pack of RJ45 connectors and boots.
My alternative thoughts are to purchase a 30m+ pre terminated CAT6 cable and then run a passthrough faceplate on each end.
What's everyone's thoughts on the above? Am I on the right track and if I went with option 2, would I notice any negative effects?
Cheers,
1 x Punch Down Tool
Cheers,
