Taking Air Cooling To A New Level?
3 Mar 2011
hey guys,
thinking of getting a H50 ( http://www.overclockers.co.uk/showproduct.php?prodid=WC-002-CS&groupid=962&catid=1532&subcat= )
for a Phenom 955 BE build, and i've been looking for a few fans to put a push/pull system on there and i found these beasts:
they're only like £20 each and are an amazing 5400RPM!!! have a look at this :D INSANE!
http://www.youtube.com/embed/tlDv0XL5bv8
they sound like jets, but im not one to care about noise :P
how cool do yah think ill be running with two of them?!?!? ;)
OCuK Should DEFINATLEY start to stock some higher RPM fans like these as im not too impressed by the ones they have atm :O
RPM isn't the only thing to think about yknow ;). Gotta remember the fan design/noise level is usually important to most people. After getting to a level of extreme noise for cooling, most would prefer switching to a custom water loop to get the same amount of cooling with a lot less noise.
Also £20 is very expensive for a single fan. D=
Good god, thats shocking. No way could I tolerate that. Years ago people use to have kittens about the noise levels of the GeForce FX 5800 Ultra's.
Is that 150CFM? can air pressure damage the fins on these radiators over long periods of time at those speeds without spacers...
no idea ;) hehee there's only one way to find out ;)
You know you have problems when you start going "eh" to a lot of people. Or you can still hear bzzzzzzzzzzzzzzzzzzzz in your sleep while the computer is off.
