Taking My 930 Further
3 Sep 2009
I have my 930 clocked at 4.2 Ghz (21 x 200)and am getting max temps of OCTT of 67 c
I am at
1.34v CPU
1.375V CPU Vtt
1.840V CPU PLL
I mainly do 3d rendering sometimes 12 hours plus high cpu stuff, my renderings are generally hitting 63 C a max but i will go by the octt at 67 C as worst case scenario
How much further could i take this bearing in mind i do long rendering episodes.
What would be th safe max temo to hit in OCTT ? 70C 75 C ?
Should i stop now as mu cpu voltage is at 1.34 V if i can go further what should i consider my max voltages to be ?
I am cooling with air by the way
If I push on i have spent a lot of time finding stable setting, what adjustments would cause the least overall change of the other setting ?
Should i raise the multiler to 22 or raise the BCLK. or both ?
I have turbo boot off, if i switch it on how will thi effect stability ?
I am running 6 GB Corasir 1600 RAM at 9 9 9 28 2T 1.6V
MB is Gigabyte GA-58XA-ud3r
Sorry so many questions
