taking XP pro off a network
rjk
rjk
OcUK Staff
8 Aug 2007
hi guys-
i have an xp pro machine linked to our network at work
basically i need to take all the users off it and remove it from the network and get it to go straight to windows desktop once it boots.
i have done this before but cant remember [brain fart] how to do it after working with vista business for so long
any links or guides or tips would be cool
cheers
Remove from domain
Remove users.
Remove user areas - that is if it stores user areas on the network.
Remove Shared Files/Folders - that is if you want to.
Create a single use without a password
Done :)
spyware/virus 's often try to use the credentials "administrator" "blank" when installing themselves
