Talent contest in work - tech help needed
9 Dec 2009
Bristol
Hi GD
We're organising a karaoke contest in work and have a budget of £300 but want as much of this as possible to go on prizes, so need to keep the cost of equipment to a minimum.
So far we have mustered:
  • A little Marshall 10w guitar amp
  • An old laptop
  • There is a 32inch flatscreen tv on the wall we can connect to.
  • We can NOT connect to the company network so will need to tether to a mobile.
This is what we want to do:
Have the laptop down in front of the performers playing YouTube videos with lyrics AND these lyrics being displayed on the wall TV for people to sing along to.
Purchase a couple of microphones (USB?) which the performers use that are somehow connected so their voices can be combined with the music from the YouTube videos and played through the Marshall amp.
Hiring karaoke equipment won't leave enough money for prizes.
Is this doable?
What software and wires will we need?
Is there a better way?
Thanks
Don't think a guitar amp will accept a USB connection not sure cal so if you can have multiple mics going through the amp.
Probably better off hiring something tbh.
I’d be considering tablet apps (plus amp and mics) or DVDs if you have a player at work.
That's an idea, we have an old dvd player and screen thing in a box at home that looks like a laptop.
The reason for YouTube is whatever the request is we'll be able to play it.
The main problem is made mixing the voice output with the music and running it out to the amp.
Any ideas?
It's really bizarre that your company has given you such a small budget and added the restriction of not being able to use the company network. The word miserly comes to mind.
Just have the 0.000000014% of people at your workplace who are actually keen on the idea go to a karaoke bar after work.
This. :D
Surely just have two sound outputs. One speaker for the tablet/dvd player/whatever, another for the mics (either directly or via a laptop). Bodge it. Or maybe a laptop with USB mics and a DVD drive... play the DVD and have the mic sound as well... all out of the headphone jack.
Also get some stupid, cheap props. Some wigs, an inflatable guitar, etc. Points for style.
I think you're right Moses. Last summer was easier because we did a lip sync battle so only needed the one output. I have a bluetooth speaker which is surprisingly loud and we could run the YouTube music to that from the laptop via a 3.5mm jack.
For the audience we could run a vga to hdmi lead to the wallmounted TV from the laptop.
For the singing we can simply run the mic into the amp, but that limits us to only 1 mic which isn't ideal because many people won't perform on their own but will join in with friends.
Any ideas on how to run 2 mics into one amp input?
Yes we've got plenty of props :) Last year we bought life-size cardboard cutouts of Beyonce and Ed Sheeran too but these were auctioned off afterwards for charity.
Any help with the mic problem will be much appreciated.
Maybe get some of those 99p USB soundcards off ebay and plug them into a hub and the laptop? use the laptop to mix the sounds together.
Hi GD
  • An old laptop
Is this doable?
Thanks
Luckily karaoke is a fairly niche thing so the resale value of stuff is peanuts, I'd suggest checking Gumtree, Freecycle, local Facebook groups, etc. Gotta be tons of stuff lying in attics.
Great idea, one of those with a stereo 3.5mm splitter should enable 2 mics to be used and we can run the output to the amp with an adapter.
