Talk Talk - ADSL Settings - Private Cable Modem + Router
7 Feb 2010
I'm looking for a little help getting the talk talk settings for my new Linksys X2000 ADSL Wireless Router.
I have the data below so far but having no success. Anyone able to check if these are correct or even have the X2000 on talktalk?
Wireless LAN Settings
Connection Type : PPOA
NAP : ENABLE
Encapulsation Mode: VCMUX or VC Base
Auth Mode: Auto
Connection Trigger: Always On
NTU: 1432
MSS: 0
Service Type: UBR Without BCR
PVC: 0
Virtual Circuit Identifier - VCI: 38
Virtual Path Finder - VPI: 0
Also found these on OcUK
I set up the same router on Homecall (Tiscali are the ISP). many of the settings ar ok on auto but check the details below
It should be straightforward.
Check you have a DHCP server running on the router and an automatic IP on your network card
check your email address and broadband password (case matters!)
[font=Arial, Helvetica]Virtual Circuit Identifier - VCI[/font]
[font=Arial, Helvetica]38[/font]
[font=Arial, Helvetica] Virtual Path Finder- VPI[/font]
[font=Arial, Helvetica]0 [/font]
[font=Arial, Helvetica] Encapsulation Mode[/font]
[font=Arial, Helvetica]VCMux [/font]
[font=Arial, Helvetica] Authentication Type[/font]
[font=Arial, Helvetica] CHAP[/font]
[font=Arial, Helvetica] Protocol[/font]
[font=Arial, Helvetica] RFC 2364:PPP over ATM (PPPoA)[/font]
[font=Arial, Helvetica] Modulation Type[/font]
[font=Arial, Helvetica] G.DMT or Auto[/font]
[font=Arial, Helvetica] Primary DNS Server[/font]
[font=Arial, Helvetica] 212.74.112.66[/font]
[font=Arial, Helvetica] Secondary DNS Server[/font]
[font=Arial, Helvetica] 212.74.112.67[/font]
