My talktalk broadband account was enabled 6 days ago and i got round to trying to set it up on saturday.
My problem is that I can't configure my router correctly. The line and account work fine as i am connected now using the usb modem supplied.
My router is configured correctly as far as I can tell. The router will get a full connection to the internet without problems. The problem is that even though it is connected, and the router can be pinged externally, and the local network settings seem correct, ip, subnet mask, default gateway and DNS wise, I still can't access the internet, can't even ping external ips.
The router is an old Conexant Model, same as this one. The local network is wireless with a Linksys WAP plugged in, and there are 3 desktops and 2 laptops all wirelessly.
I shall post some screen shots shorlty (need to disconnect and connect the router first) and if someone could look over them and suggest where I am going wrong i would really appreciate it. Thanks
