- 25 Jun 2005
TalkTalk have been our ISP for quite a while now, no real issues or problems.
Thinking of upgrading to fibre optic with them.
I currently use a Draytek Vigor 120 Modem and an Asus RT-N66U Router.
I would guess the Draytek becomes redundant, but will the Asus still work ok?
Do TalkTalk provide a modem or a modem/router in one? If it's the latter can you use it just as a modem so I can keep using the Asus?
The Draytek is connected to the master phone socket by a 5 or 6m cable that is hidden under the floor (the Draytek/Asus are in one room and the phone socket is in another), would the fibre modem be ok on that length of cable or would it need to be next to the socket?
Do TT just send the bits and let me get on with it or is an engineer needed?
Sorry for all the questions......
