Hi, have been playing with Ubuntu installed as a file image on the hard drive of a vista machine. Everything is working fine, except I can't connect to the outside world....
I've downloaded and installed the TAP-32 network thing via openVPN. I know I'm supposed to try bridge the connections then unbridge and share the LAN that I normally connect to the rest of the world with in Vista.
However, no dice, and can't configure the network, been trying all known IPs, including 192.168.0.1, 192.168.1.1, the ones I get from my home network, 192.168.0.7, the ones at work, 129.xxx.xxx.xxx.xxx, and their relevant gateways and dhcp servers.
Am assuming Ubuntu can see the TAP network adapter as I can configure IPs for it.
Cheers
Cheers
