Paving is the cheepest, plus if you tarmac or concrete you need planning permission from the council.
Also, i personally think paving looks better.
PlanningPortal said:There are no restrictions on the area of land around your house which you can cover with hard surfaces at, or near, ground level.
However, significant works of embanking or terracing to support a hard surface might need a planning application. Alternatively, an elevated patio or decking, especially if it creates useable space underneath, might be regarded as an extension or garden building, and subject to the appropriate limits. You will also need to apply for planning permission if the hard surface is not to be used for domestic purposes and is to be used instead, for example, for parking a commercial vehicle or for storing goods in connection with a business. Ask the council if in doubt.
You must obtain the separate approval of the highways department of your council if a new driveway would cross a pavement or verge. You will also need to apply for planning permission if you want to make a new or wider access for your driveway on to a trunk or other classified road. The highways department of your council can tell you if the road falls into this category.
Personally paved/patterned concrete looks better.
Tarmac looks awful so I would go for paving stones or concrete. We've got stamped concrete cobblestones, like below.
Make sure you use someone reputable.
Hmm thanks. Looks like the best compromise is reclaimed flags. I'll be parking 2 cars and a motorbike on it.
Yeah. They normally come in large slabs and are just dropped next to each other and cemented down.Is that just like concrete with a mould or something pressed ontop of it?
Ours has been down for over 10 years and has only worn a little in some areas (near the front door). You are meant to use some protective liquid to prevent weathering etc but we haven't done this I don't think.They look great but the only problem is the finish doesn't last forever. Ive seen a few now where the finish including the colour has worn away where people have been walking through. It might need re treating every few years or so?.
Don't use flagstones if you are parking cars on it. The flags will sink where the weight is on them and it will end up uneven and awful looking in no time. I personally would go with tarmac but brick paving also looks quite good.
