Firstly apologies if this is being posted in the incorrect forum.
I recently installed the AMD Dual Core Optimizer on my FX-60 rig.
To see if it was making any difference I loaded some games and then "Ctrl-Alt-Deleted" to Task Manager whilst the game was running, to take a look at the "Performance" tab.
I noted that there were 2 graphs to represent the 2 cores.
On some games, both graphs were running at the bottom of of each graph whilst CPU usage was at 0 to 3pct. Other older games had the left graph running at almost the top of the graph whilst the right hand side one was running at the bottom. CPU usage was 50pct.
I don't understand what is going on here. I would have thought that both graphs should be showing CPU usage if both cores are being utilised.
Am I mistaken in my belief ?
Is the Dual Core Optimizer not working or have I completely mis-understood it's use ?
I went into my BIOS and noted that "Cool and Quiet" is enabled even though I have not installed the appropriate software from the AMD install disc.
Perhaps that is the issue ???
Should "Cool and Quiet" be disabled ?
Should I be doing something different to see if both cores are being used ??
Appreciate all advice given
cheers
cheers
