Evening all.
Does anyone know of a way to do multiple conditions for a task in tasker?
For example, "if its 9-5 and m-f, do x".
At the moment I can't see a way to have more than one initial variable...?
Unless I'm misunderstanding you, that's not what I'm getting at.
I'm fine putting multiple actions in. Its the INITIAL variable. That says "if phone is face down". I can't find a way to say "IF phone is face down AND the phone is receiving a call THEN perform task x"
Just long press the original context (e.g. Face down) and click 'add' (and add the receiving call argument). The task will only run if all the context arguments are met
