Bit of background, last night had to run an errand, took the car, noticed water temps fluctuating between 90-120 (indicated), now the Alfa's temp gauge does fluctuate quite a bit, but not that much, higher speeds returned the temp back down to 90ish.
Today, wife takes the car on a shopping trip, probably had 5 minutes use getting to the supermarket and back.
When I returned from work, I noticed a leak from the underside of the Engine. As you do I tasted it to figure out what it was, and it tasted sweet, which leads me to believe it's antifreeze, so most probably a shot radiator.
(Great...)
I'll be booking the car in early next week, as it's due its yearly service next month anyway. I dont really want to move it, but, is it ok to top up the radiator with say bottled water for the 5 minute trip to the dealership?
Also, there's no point in fixing the radiator is there? (is it even possible?) Seeing as it's on its original radiator (7 years) Im guessing a replacement is the sensible thing to do?
(Great...)
