Oh, I will, just be so nice tohave a chip like that in a short case. If the PSU was on the case side, I could. What case do you have?Well this may be a silly question but why are you putting a high performance chip in a tiny tiny case? and what gpu will also be going into it?
If you pick another case with the capability of mouting a 240mm aio you will be fine but the limited support for 120mm aio I would think that would limit you to a 5600x.
You may want to look in the cooling or case sections to see if anyone else has used this case and what they managed to achieve. My advice is to use a bigger case with support for larger coolers.
Water kind of freaks me out being in a system. Will that air cooler be good enough?My 5900x uses 120w when I run prime95. It does not use that much when gaming. I would say aim for at least a 240mm AIO or a decent large tower cooler to keep it cool.
You can lower the chips TDP if your worried about cooling, you will lose a bit of MT performance but ST should be mostly unaffected.I am wanting to put a Ryzen 9 5900/50x in a SG05, but their is no LP cooler that will cool that enough right, with out doing anything to the chip?
I'm running a 5800X which will try to pull 140w if left to its own devices but I restrict it down to 115w and actually get slightly better performance than stock. You can do this by changing the PPT TDC EDC settings or you can change the chips default TDP settings from 105w to 95w or even 65w.
Agreed, if it can't be it's true self in my sys, I will just save the $$ and get a cheaper one.Joxeon is not suggesting you overclock the chips , just letting you know you can limit the chip to only use as much power as you want it too. Why would you want to limit a 5900x/5950x to give the same performance as a 5600x when you could save hundreds of pounds by just buying a 5600x in the first place.
I still cannot work out why you want such a powerful cpu in a tiny case and what gpu you will also be squeezing into the case as well.
