- 18 Oct 2002
- Stockton.
Just looking for some info on a recent upgrade from a 7970 to a 980Ti..
I have a watercooled system that ran quite happily with the 7970 and a 4770K cpu and a moderate overclock on both..
i swapped the 7970 (with a TDP of 300watts) for a 980ti (with a TDP of 250watts) so by that logic i expected in the same games i would experience similar (or possibly lower) temps...
but it actually is the opposite.. temps would be rock steady around 45 - 50 degrees on the 7970, and now the 980ti pushes temps to 65 - 70 degrees and above and with a louder fan profile on the radiator..
I have checked the loop for seating issues and airlocks etc, so i dont feel its a watercooling fault..
I also understand the cpu may be working a bit harder with than before, but i really expected a lower TDP card to output less heat?
or have i missed something somewhere ?
cheers!
cheers!
