Tea Infusers (Pots)
Caporegime
25 Jul 2003
FR+UK
I'm looking for a decent tea infuser, 0.5-1ltr is fine capacity wise.
Was looking at a few Bodum one's, but not sure they accept loose tea (just leaves?), but I really need one for (fine) loose tea.
Adagio Tea Do a great little infuser that you put the tea and hot water in, leave it for a few minutes then hold it over your mug / cup and press it down - the water goes through a valve in the base and filters the tea and then stops when you pick it up again!
Its called the ingenuiTEA - funky name!
I tend to just put a pinch of fresh tea in the bottom of the mug - none of this filtering lark! that little one cup filter is a bugger to keep clean!
On a separate note - what tea you drinking? Any recommendations? I am really into Oolong at the moment.
Rich
Rich
That looks nice Rich. Any idea what size cups it is for?
As for teas I drink: Ceylon (my current favourite), Green, Jasmine, Chinese, Oolong, Lapsang and Traditional English ;).
excuse me, I appear to have wandered into an episode of "Gays throughout history"
It holds about 2 cups worth apparently (or 16oz if you are a Yank).
Rich
Ahhah, sweet. Ordered one earlier anyway :D.
Sweet! When I get some more cash I am going to order the Diggnation special blend tea (if you are a Podcast fan, thats where the Diggnation tea is from) and possible that little device! you will have to tell me what it is like!
(or add me on MSN if it's alright! should be in trust!)
Rich
