Team Fortress 2 connection problems
8 Aug 2010
Somerset
Every time I've played tf2 over the last few days it has either not connected or said it has a connection problem after 10 seconds of playing, this happens every time I connect to a server and then after around 5 failed connections windows tells me I have a connection problem and my Ethernet is unplugged, I then have to spend 10 minutes messing around making windows realise it's not until I can use the internet again. This is really starting to annoy me and i just want to know if anybody's had the same problem or heard about a problem similar to mine.
If we are talking about the BT Home Hub they are known to have problems with valve games and there is not much u can do other than change your router:)
