I recently bought and installed this RAM, went into BIOS and made sure the XMP profile was enabled. In the BIOS I saw the voltage increase from 1.2V to 1.35V and it stated that it was running at 3600Mhz. I then booted into windows without issue and saw in my device info that the RAM was recognized as 3600Mhz.
However, after running CPU-Z it showed that the RAM was only running at 3200Mhz (2x1600Mhz)?? When I check out the memory info in the CPU-Z app it says that it should have an XMP profile capable of 3600Mhz 1.35V??
Any help would be greatly appreciated!
My setup is:
Gigabyte z390 UD (BIOS F8)
i7 9700k stock
*Edit: So resetting the CMOS has raised it to 3466Mhz.. Anyone got any ideas how to get it up to 3600?
My setup is:
i7 9700k stock
