Hi,
I have purchased a system from OCUK and have the following components:
Ryzen 7 1700
Asus Crosshair 6
16GB of 8pack Team Group Dark Pro 3866
OcUK Tech Labs 240mm AIO
paired with my existing :
970 gtx x2 (SLI)
Samsung Evo 850 ssd 500gb
Crosair V128GB2 sdd
Western Digital 3tb hdd
850W Supernova bronze psu
case fans: 5x 120mm
So I have the latest AGESA update and im trying to get the ram to run at the frequency advertised:
https://www.overclockers.co.uk/team...3866mhz-dual-channel-kit-black-my-08r-tg.html
As it states: "With a super high frequency of 3866MHz. Tested reliably in Asus Crosshair 6 and Asrock Taichi AMD 370 chipset Ryzen boards and Intel Z270/X299"
Now this makes it appear that this should be able to run at this speed on this set up. One reason why I purchased it + the ryzen (AMD fan boy when it comes to CPUS
Ram/
Frequency:
- is this possible or do you have any tips on how to achieve this or if its just a lottery if you can?
(Currently running this at 3600 stable which im told is good as it is by customers support)
SLI/970x2 (One MSI Twin Frozen and one Asus Strix)
- Have you heard of any SLI issues on ryzen or with this chipset? getting some crashes, could be my card but its unlikely as they have been tested on their own, but then could also be the bridge I guess?
Current system OC is: (im not an experiences OC'er so these were setting from trial and error + with AMD official oc guide mixed with the 8 pack guide from youtube)
CPU: 3880Mhz @37.25 / 104.2 bclk
Core Voltage: 1.375 (CPUZ core voltage sitting at 1.330-> 1.352)
Soc: 1.16250
Dram: 1.35
Dram Freq: 1805.5mhz (3612mhz) 18/19/19/39
Any help on the SLI and Ram or tips would be greatly appreciated for this 1st time OC'er.
Cheers,
Chris
Ryzen 7 1700
Asus Crosshair 6
970 gtx x2 (SLI)
Crosair V128GB2 sdd
case fans: 5x 120mm
Ram/
Frequency:
Soc: 1.16250
Dram: 1.35
Cheers,
Chris
