Just noticed this had a big price reduction and ordered 2 lots of 2x16Gb, judging by the specs it will run rings around my Corsair LPX vengeance. Heres to hours of running MemTest and overclocking fun and games, should be here Monday.
your primary timings are very agressive tbh, changing any others in the bios will lead to instability or no post, i run mine at the out of box cl14,15,15,15,35 and trc is set to 55 vs stock of mid 80's, command rate is set to T1 but i managed to get them to 3733mhz, if i try anything more my stystem refuses to post, if i took out a set and just ran 2 sticks i may be able to push more but i'd loose 16gb, for me thats too low, gaming at 4k with a few tabs open i can see around 14-15gb usage, hence i use 4 sticks 32gb total.
i altered my tRFC and tFRC (alt) to 325 and 313 from stock which was close to 600+ any lower and above my system refuses to post
How low will this RAM go, am now at tFRC at 250 fully stable, this memory just keeps on going with low latency.
Still running my 2 x 16GB kit (3600C16) @3800 C14.Just noticed this had a big price reduction and ordered 2 lots of 2x16Gb, judging by the specs it will run rings around my Corsair LPX vengeance. Heres to hours of running MemTest and overclocking fun and games, should be here Monday.
How many volts you putting into that?Still running my 2 x 16GB kit (3600C16) @3800 C14.
Also still on motherboard BIOS ComboAM4PIV2 1.2.0.3b when AGESA ComboAm4v2PI 1.2.0.7 is now out. Dont think i'll bother updating as all is working well
BIOS is set to 1.4900V which is reported in Zentimings.How many volts you putting into that?
mmm fair play. maybe i'm overvolting mine at 1.48 for 3600 C14? may drop it a little and see what happensBIOS is set to 1.4900V which is reported in Zentimings.
BIOS also reads 'DDR Voltage' 1.520V
I've had it set for over a year now and it passed Anta 777 extreme, RunMemTest-Pro-v2.5 and a 24 hour run of Karhu. Prior to these tests / settings I was testing other settings and voltages.
I've not touched the settings for some time thought now.
I did try some Corsair Dominator platinum RGB (£214) 3600/C14 to see if I could get 4000C14. Nope, no chance. It wasnt any better than this so returned it. Even 3600C14 (XMP) didnt pass tests so it went straight back
Are you, maybe?mmm fair play. maybe i'm overvolting mine at 1.48 for 3600 C14? may drop it a little and see what happens
