Team Group Pro Dark DDR4 help
17 Nov 2008
Black country
Hey guys Need some help I am currently running.
2 x 4GB DDR4 3000 15-15-15-35 1.35V the problem being I cant seem to run them @ 3000 with out using up to 1.4 / 1.5v on my motherboard.
They also don't seem to be good over clockers but price is great I have managed to tweak settings.
3067 @ 14-15-15-30 1.4 v.
any one currently using these modules point me in the right direction/tips?
I had a mess around with my ram recently too after i was struggling to get stability at rated speed.
What voltage are you playing with?
The ones to try are
Ram voltage - 1.35v or close to
VccIO - try between 1.1 and 1.2v
VccSA - try between 1.15 and 1.25v
tried voltages from rated 1.35 up to 1.5v anything less than 1.4v when @ rated 3000 speed and its a no boot.
VccIO and VccSA had no effect last time I tried ill give it another go.
EDIT... voltage @ 1.4v motherboard error beeps for memory will only boot 3000 @ 1.5 VccIO VccSA have no effect
Is the boards bios up to date.
Try using the matching pair of slots furthest from the cpu.
So if you are counting them 1-4 with 1 being next to the socket, use 2+4
Yes you will.
Did you do this overclock yourself or was it part of a purchased bundle? if you did it yourself you should be able to make a note of the settings used and reapply afterwards.
did it my self.
I mean if I update the bios on the board I will no longer be able to overclock the cpu as overclocking will be locked out for non k processors with a bios update I'm led to believe.
