Team Vulcan DDR3 PC3-19200C11 2400MHz
12 Nov 2014
Westgate On Sea, Kent
I have 2 x 4GB installed in slot 1 and 3 on a Gigabyte Z97X-SLI Motherboard and a Intel i5-4690k. Everything is set to standard optimal settings. I have run GPU-Z and for some reason it tells me i have different memory in the pc rig.
Memory (RAM)
Size8192 MB
Type DDR3-1333 - Dual Channel
Frequency 666.5 MHz (1:5)
Timings 9-9-9-24
Slot #1 ModuleTeam Group Inc. - 4096 MB (10700)
Slot #2 ModuleTeam Group Inc. - 4096 MB (10700)
can anyone advise please why it is running at this Mhz. i did notice that the SPD table had a XMP and 4 j#dec settings but i have not altered or changed any of these.
I dont understand why it is running at a different Mhz than it should be when all values set to auto which is the motherboard defaults.
Memory (RAM)
Size8192 MB
Type DDR3-2399 - Dual Channel
Frequency 1199.8 MHz (1:9)
Timings 11-13-13-35
thank you.
