- 26 Aug 2010
- West Yorkshire
So i've been setting up a new build with some 2666mhz memory, however this only defaults to 1333 when booting. The motherboard only has a maximum setting of 2400 without manually changing clocks, so i set it to that speed, pop in the timings that the ram specifies (11, 13, 13, 35) and the computer just fails to boot. Are there any other settings i should be looking at to run at the full speed?
