Teamgroup Memory
11 Jul 2017
Just noticed that the timings on this memory tend to be consistently good, so I was wondering what people's thoughts on this stuff are? Is it good quality memory? It seems to be.
You should still aim for a low CAS. Not all TG memory is the same. 3200C14 DDR4 tends to be the best for most purposes. Look for the IC manufacturer and die information before purchase.
Team group stuff is very solid they are the oem for my range of memory. All 8Pack kits are the highest quality Samsung ic with very strict binning.
Go with the 8 pack stuff can't go wrong!
The timing on that stuff is so vastly superior to the competition, I struggle to understand why people still buy other brands. I guess that's why I asked the question though, it's such good stuff it's hard to believe.
On ocuk most people do buy the 8Pack stuff to be honest.
The IC and every aspect of this memory was selected and tested by me and then built by team group to perform.
