TeamGroup RAM thoughts
I'm using 2133 team xtreem ram. Had it over 1.5 years and no problems at all. Can't go wrong with team group in my opinion
Very good ram from a very reputable manufacturer. Team seemed to dissapear from the uk market for a while but glad to see them back. Ive owned several ram kits from them over the years and all have been good.
Speed/timings wise the 2400c10 frost kit is the best outright and best value of the ones listed above, but as mentioned they are tall.
Shame the vulcan red c10 kit is a bit rare now, low profile and tighter timings of 10-11-11-31. Id like to add another 8gb at some point.
Are you running at XMP timings mate? What CR are you running these at?
yep running at XMP timings. no faffing about required. never had a problem with them. I haven't started tinkering with them yet but I might try 2133 cas9 soon.
even thinking of grabbing a "frost edition" kit to upgrade to 16gb and having black and white ram (going for a black and white watercooling loop)
Very nice idea! Yeah same here fired in! XMP set in UEFI. Cooler fitted, done! Does what it says on the box!
